この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your headphone system isn't providing quality sound through each speaker, it may be necessary to replace the speaker as it could be blown or an internal wiring issue. This replacement should take no longer than 30 minutes with the use of screwdriver and plastic pry tool.
必要な工具と部品
Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
Work circularly until removed.
Using metal prying tool, gently slide the tool between the speaker and the blue plastic holder to break up the adhesive.
ある他の人がこのガイドを完成しました。
コメント 1 件
This is the first guide I've found that covers how the speaker is mounted to the plate. Thanks!
