メインコンテンツにスキップ
はじめに
In order to complete this repair, you will need to order a replacement headband to replace the defective part.
パーツ
パーツは指定されていません。
  1. Grab one end of the headband pad and pull up slightly, exposing where it is glued to to the backing. Grab one end of the headband pad and pull up slightly, exposing where it is glued to to the backing.
    • Grab one end of the headband pad and pull up slightly, exposing where it is glued to to the backing.
  2. Using a thin tool carefully scrape away the glue underneath the band while pulling the pad up, careful not to rip it. Using a thin tool carefully scrape away the glue underneath the band while pulling the pad up, careful not to rip it.
    • Using a thin tool carefully scrape away the glue underneath the band while pulling the pad up, careful not to rip it.
  3. Once the pad has been completely removed, scrape off any remaining residue. Once the pad has been completely removed, scrape off any remaining residue. Once the pad has been completely removed, scrape off any remaining residue.
    • Once the pad has been completely removed, scrape off any remaining residue.
  4. Follow the directions of the replacement pad on how to attach it to the headband.
    • Follow the directions of the replacement pad on how to attach it to the headband.
終わりに
Noah Franklin
メンバー登録日: 2015年10月27日
445 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Shastany Fall 2015 UMass Dartmouth, Team 2-3, Shastany Fall 2015人のメンバー
UMASSD-SHASTANY-F15S2G3
3 メンバー
5のガイドは作成済み
コメント1件
Where can i get headband replacements? Have looked everywhere and its just not available :(
naz - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 36
今までの合計 4,787
