メインコンテンツにスキップ
Turtle Beach Ear Force Stealth 500P Battery Replacement
必要な工具と部品
  1. Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 手順 1、 3の画像 1 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 手順 1、 3の画像 2 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 手順 1、 3の画像 3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 2、 2の画像 1 Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 手順 3、 3の画像 1 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 手順 3、 3の画像 2 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 手順 3、 3の画像 3
    • Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
    My unit only had two screws attaching the circuit board to the headset body.
    Jerry Lundy - 返信
  4. Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 4、 2の画像 1 Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 4、 2の画像 2
    • Use bent tweezers to remove two wire connector plugs from circuit board.
  5. Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 5、 2の画像 1 Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 5、 2の画像 2
    • Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
  6. Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 6、 1の画像 1
    • Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
  7. Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 7、 1の画像 1
    • Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
  8. Turtle Beach Ear Force Stealth 500P Battery Replacement: 手順 8、 1の画像 1
    • Battery will be free to be removed and replaced.
終わりに
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Noah Franklin
メンバー登録日: 10/27/15
445 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Shastany Fall 2015 UMass Dartmouth, Team 2-3, Shastany Fall 2015人のメンバー
UMASSD-SHASTANY-F15S2G3
3 メンバー
10のガイドは作成済み
3 件のコメント
Where can I get a replacement battery?
Jeremy Nocek - 返信
You can look on Ebay or Amazon. You can find it by searching the model number: ( FT603048P )
The costs are like $20-$30.
If you look on Ebay under: ( 3.7v 603048 ), you can get the same battery without the connector for like $5.
William Smith - 返信
hey i have a question, how i can repair the mute button? It does not work.
fiercecesar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 23
今までの合計 23,672
