メインコンテンツにスキップ
Turntable Disassembly
必要な工具と部品
  1. Turntable Disassembly, Remove dust cover: 手順 1、 2の画像 1 Turntable Disassembly, Remove dust cover: 手順 1、 2の画像 2
    • Start by simply lifting off and placing aside the dust cover.
    • Make sure that the turntable is disconnected from the mains.
  2. Turntable Disassembly, Lift off platter (direct drive): 手順 2、 1の画像 1
    • Simply lift off the platter with both hands and place it aside.
    • You may need push your fingers through the opening in the platter and push down a little bit to free the platter from the spindle.
    • If you have a belt-drive turntable, you will need to remove the belt off the motor spindle before taking off the platter.
    • Rotate the platter until the motor spindle and belt appear through the access hole, then gently pull the belt outwards with your thumb and lift off the platter without letting go off the belt.
    • Once the platter is off, release the belt, letting it rest around the platter inner pulley.
  3. Turntable Disassembly, Remove headshell and cartridge: 手順 4、 1の画像 1
    • Remove the head-shell and cartridge as one unit.
    • Some units have a thumbscrew that must be loosend before the headshell can be pulled off.
    • Other types use a socket-type connector. Loosen it and gently pull the headshell ff
    • After removing the headshell, make sure that the tonearm is firmly locked in its rest.
  4. Turntable Disassembly, Remove counterweight: 手順 5、 1の画像 1
    • Simply loosen the counterweight until it falls free off the tone-arm.
    • Be sure to take note of the tracking force setting before removal if you do not have the specification for your cartridge. You will have to reset this tracking force after reassembly and re-balancing of the tone-arm.
  5. Turntable Disassembly, Remove switch caps and other trim pieces: 手順 6、 2の画像 1 Turntable Disassembly, Remove switch caps and other trim pieces: 手順 6、 2の画像 2
    • Pull the plastic caps off any slide or push-button switches and keep them aside.
    • Also remove any trim pieces such as access covers for adjustments.
  6. Turntable Disassembly, Remove feet and bottom plate screws: 手順 7、 2の画像 1 Turntable Disassembly, Remove feet and bottom plate screws: 手順 7、 2の画像 2
    • Put the dust cover back on and turn the turntable upside down. Unscrew the fasteners holding each of the rubber feet to the base plate.
    • Then remove any remaining screws holding the base plate onto the plinth. The base plate can now be lifted off to reveal the internals.
    • You may need to wedge a flat-blade screwdriver between the plinth and base plate to lift it off.
    • You can now access the motor, power-supply, and main circuit board for repairs or servicing
  7. Turntable Disassembly, Remove control PCB (optional): 手順 8、 3の画像 1 Turntable Disassembly, Remove control PCB (optional): 手順 8、 3の画像 2 Turntable Disassembly, Remove control PCB (optional): 手順 8、 3の画像 3
    • You may need to remove the PCB to facilitate easier access to various components.
    • Remove any screws holding the PCB to the chassis, plinth, or to any heat sinks that would restrict removal.
    • Disconnect any cables from the control PCB to other parts of the turntable such as the speed selector switch and power supply. On some models, such as this Technics, you may need to cut the wires if no connectors are used.
    • You can now rotate or remove the PCB.
    • On many direct drive models, the motor's stator coil is soldered onto the control PCB. The motor's shaft and bearing assembly, along with its back plate may also be held onto the PCB by long screws threaded through the stator assembly. In this case, you can remove the PCB with the shaft and bearing assembly and back plate attached.
    • Power supply filter capacitors on the control PCB may be holding voltages around 20-30V.
  8. Turntable Disassembly, Seprade PCB from motor shaft assembly (optional): 手順 9、 2の画像 1 Turntable Disassembly, Seprade PCB from motor shaft assembly (optional): 手順 9、 2の画像 2
    • Rotate the control PCB along with motor assemblies, to access the screws on the top of the motor's stator assembly.
    • Remove the long screws threaded through the stator assembly into the shaft and bearing assembly.
    • You will now be able to separate the shaft and bearing assembly from the control PCB.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Santaji
メンバー登録日: 03/25/11
1,207 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 36
過去 30 日: 143
今までの合計 4,690
