メインコンテンツにスキップ
はじめに
This will tell you how to go from a printer that won't turn on to one that will.
  1. Inspect the printer to see if there are any visible damages to it.
    • Inspect the printer to see if there are any visible damages to it.
  2. Plug in the power cord tightly to the back of the printer and into an AC power source.
    • Plug in the power cord tightly to the back of the printer and into an AC power source.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Check to see if any power is now coming through.
    • Check to see if any power is now coming through.
  5. Check to see the cord is in snug enough. You should be able to hear a moderate click.
    • Check to see the cord is in snug enough. You should be able to hear a moderate click.
  6. Check the wire for strips or possibly defects.
    • Check the wire for strips or possibly defects.
  7. Consider buying a new printer cord or testing with someone who has a working one. If this still does not work, your printer may have internal damages beyond fixing.
    • Consider buying a new printer cord or testing with someone who has a working one. If this still does not work, your printer may have internal damages beyond fixing.
まとめ
Joe
メンバー登録日: 2011年10月14日
1 ポイント
4のガイドは作成済み
チーム
James Madison, Team 2-5, Allen Fall 2011 James Madison, Team 2-5, Allen Fall 2011人のメンバー
JMU-ALLEN-F11S2G5
1 メンバー
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 448
