メインコンテンツにスキップ
Tungsten E Disassembly
必要な工具と部品
  1. Tungsten E Disassembly, Tungsten E Disassembly: 手順 1、 2の画像 1 Tungsten E Disassembly, Tungsten E Disassembly: 手順 1、 2の画像 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: 手順 2、 3の画像 1 Tungsten E Disassembly: 手順 2、 3の画像 2 Tungsten E Disassembly: 手順 2、 3の画像 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    I think it's better to open from the right, not the left. The right will separate if you lever the metal back to the outside and push the plastic to the inside. The lft is more like a inge and would damage more easily.
    Just my $0.02.
    Yishai Sered - 返信
  3. Tungsten E Disassembly: 手順 3、 2の画像 1 Tungsten E Disassembly: 手順 3、 2の画像 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: 手順 4、 2の画像 1 Tungsten E Disassembly: 手順 4、 2の画像 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: 手順 5、 3の画像 1 Tungsten E Disassembly: 手順 5、 3の画像 2 Tungsten E Disassembly: 手順 5、 3の画像 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: 手順 6、 1の画像 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
終わりに
作成者
10人の作成者と共同で作成されました。
Kevin Hom
メンバー登録日: 01/21/10
103 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S13G22
4 メンバー
4のガイドは作成済み
コメント 1 件
How does one unplug the battery?
dlcatftwin - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 7,788
