メインコンテンツにスキップ
Trunk LED Tailgate Strip Light Installation
必要な工具と部品
  1. Trunk LED Tailgate Strip Light Installation, Cleaning: 手順 1、 2の画像 1 Trunk LED Tailgate Strip Light Installation, Cleaning: 手順 1、 2の画像 2
    • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
    • Use soap and water to scrub the area clean since that place is normally dirty.
  2. Trunk LED Tailgate Strip Light Installation, Mounting time: 手順 2、 2の画像 1 Trunk LED Tailgate Strip Light Installation, Mounting time: 手順 2、 2の画像 2
    • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
    • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
    • Straighten the LED strip and peel adhesive.
    • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
  3. Trunk LED Tailgate Strip Light Installation, Wire tapping: 手順 3、 3の画像 1 Trunk LED Tailgate Strip Light Installation, Wire tapping: 手順 3、 3の画像 2 Trunk LED Tailgate Strip Light Installation, Wire tapping: 手順 3、 3の画像 3
    • Tap reverse light wire.
    • You will need to remove either side of the tail light to locate the reverse light.
    • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
  4. Trunk LED Tailgate Strip Light Installation, Find the connector: 手順 4、 2の画像 1 Trunk LED Tailgate Strip Light Installation, Find the connector: 手順 4、 2の画像 2
    • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
    • You will find the trailer light connector near the tow hitch.
    These connections are wrong. The right and left signal is the brake lights. The “brake” is the running lights.
    Thomas Johnson - 返信
    My running light isn't on but the brakes and turn signals working
    Dennis Baker - 返信
  5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: 手順 5、 3の画像 1 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 手順 5、 3の画像 2 Trunk LED Tailgate Strip Light Installation, Test and enjoy: 手順 5、 3の画像 3
    • Hide the wires or zip-tie them.
    • Check the trunk LED tailgate lamp to make sure everything works.
    I don't suppose you could tell me why the reverse lights and brake lights light up at the same time in the reverse gear? Assuming it's something in the wiring in my truck cuz i just put a new 7 blade/ 4 pin harness in it
    Cashmere - 返信
    Only half of the led strip is working. How to make the whole strip work?
    Mason Lair - 返信
    Probably because the listing of the trailer connection is not correct. If you connect the brake light to the directional connection, only one side will light up.
    Thomas Johnson - 返信
    My wiring on my truck, has brake light wired in with turn signals, so when I plug in my 3in1 led light strip, everything works but my brake light, it stays orange, will on convert to red. I have tried everything, Very Frustrating!
    jomichellehill - 返信
終わりに
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,357 ポイント
23のガイドは作成済み
21 件のコメント
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - 返信
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 -
Anyone have the answer to this problem yet?
Trevor G -
I'm having the same problem!
Richie - 返信
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - 返信
I install led tailgate strip on my 2015 f150 now reverse sensers don't work
ibarraj1975 - 返信
I install led tailgate strip on my 2015 f150 now reverse sensers don't work and backup camera show like i have trailer connect its totally different any idea how to use the strip and revers camera gonna be work like before? Please any idea mirekdm@yahoo.com
mireklidia - 返信
I install the led tailgate strip on my 2006 Chevrolet 1500 and i wired the ground and brake wire in first and it worked perfectly fine, when i wired the left turn signal in as well it worked perfectly fine, after i installed the right turn signal wire the brake light part quit working. Any ideas? My email is chelseamoore1972@gmail.com
Chelsea Moore - 返信
just go a head and cancel my order
Paul Knight - 返信
Any f150 owners out there go to opt7 and get their tailgate module. It will make your tail light bar work. I had the same issues with the trailer stuff going on. It's the way Ford wired everything. I have been searching for almost a year to figure it out. I'll be taking the strip I wired onto my truck off this weekend and putting a new strip on from opt7 and their module. They told me this will fix everything. I will repost after doing this and let everyone know how it worked. I bought their 3 row 1200 led strip which is supposed to be the brightest out there. Also if any f150 owners want to upgrade their lighting go to www.f150leds.com. I have bought headlights and other bulbs from them and they are the best and brightest…
Good luck.
John Tynan - 返信
I put my led strip on and during the day I can set cruise and start the truck automatically but at night when the led stripe is on I can’t do anything bc it says my brakes are being pushed while I am driving my Silverado 1500
anyone know what is doing this at night time y is it saying brakes are on? Thank u in advance
Travis Engard - 返信
Wondering why when the headlights are on the turn signals on the light bar dont work.
Vwc - 返信
2017 F-150 The truck has all lights working. On the LED strip: My left turn signal works. My right turn signal does not. Brake light works and backup works
George Cravaritis - 返信
Did you find out what the problem was,im having the same issue but it's my left signal that ain't working!
valleystyle1 -
How or where do I cut the light strip if it’s to long????
j.cruzer - 返信
How to remove under tailgate led light strip got it to high
tom charlie - 返信
The problem everyone is having is that you would think the black wire is for ground. The manufacturer of the light bar uses the white wire as ground.
Thomas Johnson - 返信
I have a 2006 GMC Sierra I want hot wire my tail light strip light. Can some tell me where to connect the brown cable to the harness of the truck. Thank you
Nestor Melendez - 返信
I have very low voltage coming out of controller hub. What’s wrong. Bench test was good
braunbv - 返信
Using trailer socket disables holograph back-up assist on 17 F-150XLT as does wiring into the supply entering the trailer socket. Need instructions to wire such that the truck doesn't think there's a trailer hitched.
Jim Collier
JimBo Collier - 返信
I wired my 2021 F 150 and the strip doesn't work.
Camille Krieger - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 58
今までの合計 41,497
