メインコンテンツにスキップ
Tritton Kunai Right Speaker Replacement
必要な工具と部品
  1. Tritton Kunai Right Speaker Replacement, Right Speaker: 手順 1、 2の画像 1 Tritton Kunai Right Speaker Replacement, Right Speaker: 手順 1、 2の画像 2
    • Firmly grasp the black ear cushion with one hand and the white speaker frame with the other hand.
    • Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
  2. Tritton Kunai Right Speaker Replacement: 手順 2、 2の画像 1 Tritton Kunai Right Speaker Replacement: 手順 2、 2の画像 2
    • Remove the two 9 mm screws indicated in red with a PH00 screwdriver.
    • Remove the two 7 mm screws indicated in orange with a PH00 screwdriver.
    • Separate the black horseshoe shaped frame from the right speaker frame.
  3. Tritton Kunai Right Speaker Replacement: 手順 3、 2の画像 1 Tritton Kunai Right Speaker Replacement: 手順 3、 2の画像 2
    • Remove the two 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black bracket and then the rail adjustment from the right speaker frame.
  4. Tritton Kunai Right Speaker Replacement: 手順 4、 2の画像 1 Tritton Kunai Right Speaker Replacement: 手順 4、 2の画像 2
    • Remove the five 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black speaker console from the right speaker frame.
  5. Tritton Kunai Right Speaker Replacement: 手順 5、 1の画像 1
    • Disconnect the red and green wires from the 16 Ohm speaker.
  6. Tritton Kunai Right Speaker Replacement: 手順 6、 1の画像 1
    • Squeeze the tip of the tweezers into the gap between the speaker and the speaker case.
    • Remove the glue holding the speaker in place by scraping the glue with the tip of the tweezers.
  7. Tritton Kunai Right Speaker Replacement: 手順 7、 2の画像 1 Tritton Kunai Right Speaker Replacement: 手順 7、 2の画像 2
    • Remove the speaker from its circular shaped slot.
    • Apply glue to the sides of your new 16 Ohm speaker.
  8. Tritton Kunai Right Speaker Replacement: 手順 9、 2の画像 1 Tritton Kunai Right Speaker Replacement: 手順 9、 2の画像 2
    • Insert your new speaker into the circular shaped slot located on the speaker cover.
  9. Tritton Kunai Right Speaker Replacement: 手順 10、 1の画像 1
    • Solder the wires you disconnected from the old speaker to the new speaker. The red wire is to be soldered to the far right terminal, while the green wire is to be soldered to the far left terminal.
    • Here is iFixit's soldering guide.
    • Solder with caution and try not to burn yourself.
終わりに
To reassemble your device, follow steps 1 through 4 in reverse order.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Elias El Tom
メンバー登録日: 03/12/15
338 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015人のメンバー
UMASSD-DUARTE-S15S3G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,103
