はじめに
The volume buttons allow you to control the volume of audio played by the device, either though the speaker or headphones. The replacement of the volume buttons may be necessary if the tablet does not respond when the volume buttons are pressed by either raising or lowering the volume of sound.
The disassembly is very simple. You will need only basic tools and will not be required to perform any specialized tasks.
必要な工具と部品
Remove the yellow tape covering the set of wires located near the upper right corner of the battery.
2 の人々がこのガイドを完成させました。
