メインコンテンツにスキップ
Trio Stealth G2 Hype Screen Replacement
必要な工具と部品
  1. Trio Stealth G2 Hype Screen Replacement, Back Panel: 手順 1、 2の画像 1 Trio Stealth G2 Hype Screen Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Screen Replacement: 手順 2、 1の画像 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Screen Replacement: 手順 3、 3の画像 1 Trio Stealth G2 Hype Screen Replacement: 手順 3、 3の画像 2 Trio Stealth G2 Hype Screen Replacement: 手順 3、 3の画像 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Screen Replacement, Speakers: 手順 4、 2の画像 1 Trio Stealth G2 Hype Screen Replacement, Speakers: 手順 4、 2の画像 2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Screen Replacement: 手順 5、 1の画像 1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
  6. Trio Stealth G2 Hype Screen Replacement, Battery: 手順 6、 2の画像 1 Trio Stealth G2 Hype Screen Replacement, Battery: 手順 6、 2の画像 2
    • While holding the mother board down, slowly remove the battery from tape on the back of the screen.
    • Make sure to keep all wires attached for now.
  7. Trio Stealth G2 Hype Screen Replacement: 手順 7、 1の画像 1
    • In order to replace the battery once the wires are removed, you will need to solder the wires of the new battery onto the motherboard.
    • The red wire must be soldered to the "+" terminal while the black is soldered to the "-" terminal.
    • Pull the wires off the motherboard.
  8. Trio Stealth G2 Hype Screen Replacement, Motherboard: 手順 8、 3の画像 1 Trio Stealth G2 Hype Screen Replacement, Motherboard: 手順 8、 3の画像 2 Trio Stealth G2 Hype Screen Replacement, Motherboard: 手順 8、 3の画像 3
    • Peel the black tape located on the left side of the motherboard.
    • Peel the orange tape holding down the wire coming from the bottom left side of the motherboard.
  9. Trio Stealth G2 Hype Screen Replacement: 手順 9、 3の画像 1 Trio Stealth G2 Hype Screen Replacement: 手順 9、 3の画像 2 Trio Stealth G2 Hype Screen Replacement: 手順 9、 3の画像 3
    • The screws to remove the motherboard are located on the top hand side towards the charging port.
    • To reveal the screws, peel of the thin yellow film that covers the whole motherboard just until the screws are accessible.
    • Remove the three 1.2mm Phillips #1 screws using the screwdriver in your 26 Bit Driver Kit.
  10. Trio Stealth G2 Hype Screen Replacement: 手順 10、 2の画像 1 Trio Stealth G2 Hype Screen Replacement: 手順 10、 2の画像 2
    • Remove the orange tape holding the wires to the back of the screen.
    • Simply lift the motherboard of the back of the screen.
  11. Trio Stealth G2 Hype Screen Replacement, Screen/Digitizer: 手順 11、 2の画像 1 Trio Stealth G2 Hype Screen Replacement, Screen/Digitizer: 手順 11、 2の画像 2
    • To separate the screen from its casing, hold the device at its corners and gently pull them apart.
    • Carefully but firmly pull the screen out of the casing.
  12. Trio Stealth G2 Hype Screen Replacement, Digitizer: 手順 12、 1の画像 1
    • After pulling out the screen, what you have left is the digitizer, which is what allows the tablet to recognize your touch.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Antoninus Lamptey
メンバー登録日: 01/21/15
292 ポイント
2のガイドは作成済み
コメント 1 件
My screen is broken how do I get new one
Jordan 22 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 2,499
