メインコンテンツにスキップ
Trio Stealth G2 Hype Battery Replacement
必要な工具と部品
  1. Trio Stealth G2 Hype Battery Replacement, Back Panel: 手順 1、 2の画像 1 Trio Stealth G2 Hype Battery Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Battery Replacement: 手順 2、 1の画像 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Battery Replacement: 手順 3、 3の画像 1 Trio Stealth G2 Hype Battery Replacement: 手順 3、 3の画像 2 Trio Stealth G2 Hype Battery Replacement: 手順 3、 3の画像 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Battery Replacement, Speakers: 手順 4、 2の画像 1 Trio Stealth G2 Hype Battery Replacement, Speakers: 手順 4、 2の画像 2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Battery Replacement: 手順 5、 1の画像 1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
  6. Trio Stealth G2 Hype Battery Replacement, Battery: 手順 6、 2の画像 1 Trio Stealth G2 Hype Battery Replacement, Battery: 手順 6、 2の画像 2
    • While holding the mother board down, slowly remove the battery from tape on the back of the screen.
    • Make sure to keep all wires attached for now.
  7. Trio Stealth G2 Hype Battery Replacement: 手順 7、 1の画像 1
    • In order to replace the battery once the wires are removed, you will need to solder the wires of the new battery onto the motherboard.
    • The red wire must be soldered to the "+" terminal while the black is soldered to the "-" terminal.
    • Pull the wires off the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Thomas Lichtenberger
メンバー登録日: 01/21/15
459 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015人のメンバー
USFT-BROWN-W15S4G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 2,298
