メインコンテンツにスキップ
Trio AXS 3G Battery Replacement
必要な工具と部品
  1. Trio AXS 3G Battery Replacement, Back Case: 手順 1、 1の画像 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Battery Replacement: 手順 2、 2の画像 1 Trio AXS 3G Battery Replacement: 手順 2、 2の画像 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Battery Replacement: 手順 3、 1の画像 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Battery Replacement, Battery: 手順 4、 1の画像 1
    • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
  5. Trio AXS 3G Battery Replacement: 手順 5、 1の画像 1
    • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
  6. Trio AXS 3G Battery Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Use the plastic card to pry the battery away from the device.
    • The battery is attached to the tablet by glue.
  7. Trio AXS 3G Battery Replacement: 手順 7、 1の画像 1
    • Peel off the battery from the device to completely remove it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Michaela Causey
メンバー登録日: 09/20/17
328 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S7-G6, Thomas Fall 2017 University of North Texas, Team S7-G6, Thomas Fall 2017人のメンバー
UNT-THOMAS-F17S7G6
3 メンバー
12のガイドは作成済み
2 件のコメント
where can i buy a battery replacement? can it work without a battery?
millie abanilla - 返信
where can you buy a replacement battery
J W - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 21
今までの合計 1,213
