メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Trim a Webbing Belt
必要な工具と部品
  1. Trim a Webbing Belt, Turn on the hot knife: 手順 1、 1の画像 1
    • Turn on the hot knife to allow it time to heat up.
    • Alert those working nearby that the hot knife is on.
    • Melting plastic on the hot knife causes noxious fumes. Turn it on only while using it, and only use it in a well-ventilated area or outside.
    FixBotに聞いてみる
    コメントを追加
  2. Trim a Webbing Belt, Mark the correct size: 手順 2、 1の画像 1
    • Put on and fasten the belt into a pair of pants in the same manner it will be worn.
    • Use chalk or a heat-erasable pen to mark the new end of the belt.
    • Remove the belt for cutting.
    FixBotに聞いてみる
    コメントを追加
  3. Trim a Webbing Belt, Draw the tip design: 手順 3、 3の画像 1 Trim a Webbing Belt, Draw the tip design: 手順 3、 3の画像 2 Trim a Webbing Belt, Draw the tip design: 手順 3、 3の画像 3
    • There are three standard tip designs with different aesthetics and functionality:
    • 45 Degree or Point - This tip design is the easiest to feed through a buckle, but has the highest likelihood of fraying in the future.
    • Square End - This tip design is the least likely to fray.
    • Corners Cut - This is a hybrid of the point and square designs.
    • Draw the desired tip design at the mark made in Step 2 with chalk or a heat-erasable pen.
    FixBotに聞いてみる
    コメントを追加
    • Use a scrap piece of webbing to test that the hot knife has come up to temperature. The knife should easily melt through the webbing.
    • Holding the belt tight from both ends, carefully cut on the marked line.
    • Use a pair of pliers to hold the webbing if the mark is close to the end.
    • Save or discard the removed webbing responsibly.
    • Allow the belt to fully cool before handling.
    • Turn off the hot knife and alert those working nearby that the knife is off but still hot.
    FixBotに聞いてみる
    コメントを追加
    • If needed, use a lighter to melt and soften the melted edge on both sides until it has the desired smoothness.
    • Allow the belt to fully cool.
    • This method can also be used to repair any future fraying.
    FixBotに聞いてみる
    コメントを追加
  4. Trim a Webbing Belt, Alternative method: 手順 6、 3の画像 1 Trim a Webbing Belt, Alternative method: 手順 6、 3の画像 2 Trim a Webbing Belt, Alternative method: 手順 6、 3の画像 3
    • To shorten a webbing belt without a hot knife:
    • Follow the marking instructions in Steps 2 and 3.
    • Cut along the line with a pair of sharp scissors.
    • Then use the technique in Step 5 to melt the cut edge until it's fully encased and no frayed pieces remain.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Zach Mueller
メンバー登録日: 02/23/23
1,789 ポイント
9のガイドは作成済み
チーム
Patagonia Patagonia人のメンバー
Community
9 メンバー
153のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 219
今までの合計 2,394
