メインコンテンツにスキップ
Triace A310 Chain Replacement
必要な工具と部品
  1. Triace A310 Chain Replacement, Tire: 手順 1、 1の画像 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Chain Replacement: 手順 2、 2の画像 1 Triace A310 Chain Replacement: 手順 2、 2の画像 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Chain Replacement: 手順 3、 2の画像 1 Triace A310 Chain Replacement: 手順 3、 2の画像 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Chain Replacement, Chain: 手順 4、 3の画像 1 Triace A310 Chain Replacement, Chain: 手順 4、 3の画像 2 Triace A310 Chain Replacement, Chain: 手順 4、 3の画像 3
    • Locate the master link along the chain.
    • Note: If the master link matches the one pictured in this step continue with the instructions, if not skip to the next step.
    • With pliers squeeze the two pins together so that the chain comes apart.
  5. Triace A310 Chain Replacement: 手順 5、 3の画像 1 Triace A310 Chain Replacement: 手順 5、 3の画像 2 Triace A310 Chain Replacement: 手順 5、 3の画像 3
    • Note: This step is only for chains with a master link clip.
    • With a plier press the two pins together and remove the clip.
    • Once the clip is removed the chain should easily come apart.
  6. Triace A310 Chain Replacement: 手順 6、 1の画像 1
    • Once the chain is separated, remove it from the bike by pulling one end.
  7. Triace A310 Chain Replacement: 手順 7、 3の画像 1 Triace A310 Chain Replacement: 手順 7、 3の画像 2 Triace A310 Chain Replacement: 手順 7、 3の画像 3
    • With the new chain, place it on the current gear that your bike is in.
    • Note: If you don't know which gear your bike is in place the chain on one of the middle gears.
    • Thread one end of the chain through the derailleur from top to bottom so it is in the shape of a 'S'.
    • Next place the chain on the back gears, making sure that it is threaded through the guide.
  8. Triace A310 Chain Replacement: 手順 8、 3の画像 1 Triace A310 Chain Replacement: 手順 8、 3の画像 2 Triace A310 Chain Replacement: 手順 8、 3の画像 3
    • To reassemble the chain bring both ends of the chain together so that the pins on each one lineup.
    • Grip the chain on both sides of the master link and pull.
  9. Triace A310 Chain Replacement: 手順 9、 3の画像 1 Triace A310 Chain Replacement: 手順 9、 3の画像 2 Triace A310 Chain Replacement: 手順 9、 3の画像 3
    • If your chain does have a master link clip replace the link around the two pins.
    • Use a plier to slide the clip back into place.
終わりに
Once your chain is back together, you are ready to once again, hit the trails.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jacob Rickman
メンバー登録日: 01/26/14
159 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S1G37
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 14
今までの合計 752
