メインコンテンツにスキップ
Trek 4300 Bicycle Rim Replacement
必要な工具と部品
  1. Trek 4300 Bicycle Rim Replacement, Front Wheel: 手順 1、 2の画像 1 Trek 4300 Bicycle Rim Replacement, Front Wheel: 手順 1、 2の画像 2
    • Stand facing your bike and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
  2. Trek 4300 Bicycle Rim Replacement: 手順 2、 2の画像 1 Trek 4300 Bicycle Rim Replacement: 手順 2、 2の画像 2
    • Unhook the brake wire in the metal tube from the brake wire holder on the brake caliper in your left hand.
  3. Trek 4300 Bicycle Rim Replacement: 手順 3、 1の画像 1
    • Find the quick release lever located on the bikes fork to loosen the wheel from the frame.
    • Lift the lever from lock position 180 degrees until the open sign on the lever faces outward. Twist the lever while holding the pin on the opposite side of the wheel.
    • The quick release lever does not need to be completely removed.
    • Note which side of the bike the quick release lever is on for proper reassembly.
  4. Trek 4300 Bicycle Rim Replacement: 手順 4、 2の画像 1 Trek 4300 Bicycle Rim Replacement: 手順 4、 2の画像 2
    • Pull the frame of the bike upwards to separate the front wheel.
  5. Trek 4300 Bicycle Rim Replacement, Rim: 手順 5、 1の画像 1
    • To deflate the tire, remove the cap and attach the pump head to the valve. You should then hear air flowing out from the tire.
  6. Trek 4300 Bicycle Rim Replacement: 手順 6、 1の画像 1
    • Push the valve upward through the hole in the rim.
  7. Trek 4300 Bicycle Rim Replacement: 手順 7、 2の画像 1 Trek 4300 Bicycle Rim Replacement: 手順 7、 2の画像 2
    • Pull the tire away from the rim until you can insert your fingers under the tire coping to remove it from the inside of the rim.
    • Slide your fingers (still under the tire coping) around the circumference of the tire until you completely remove the tire from the rim.
    • It is easier to start removing the tire from the rim near the location of the valve.
終わりに
作成者
2人の作成者と共同で作成されました。
Erin Ferguson
メンバー登録日: 10/13/14
447 ポイント
4のガイドは作成済み
チーム
Clemson, Team 3-2, Benson Fall 2014 Clemson, Team 3-2, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S3G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 1,037
