はじめに
Removing the inner tube from your bicycle is the same process for both the front and rear wheel even though this guide specifically demonstrates the front wheel. If you want to remove the tube from the rear wheel first see the guide demonstrating how to remove your rear wheel then follow this guide to remove the tube.
必要な工具と部品
Stand facing your bike and locate the brake calipers.
To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
To deflate the tire, remove the cap and attach the pump head to the valve. You should then hear air flowing out from the tire.
