メインコンテンツにスキップ
Traxxas Summit Steering Assembly Servo Replacement
必要な工具と部品
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: 手順 1、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: 手順 1、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: 手順 1、 3の画像 3
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: 手順 2、 2の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 2、 2の画像 2
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: 手順 3、 2の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 3、 2の画像 2
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: 手順 4、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 4、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement: 手順 4、 3の画像 3
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: 手順 5、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 5、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement: 手順 5、 3の画像 3
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: 手順 6、 2の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 6、 2の画像 2
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: 手順 7、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 7、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement: 手順 7、 3の画像 3
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: 手順 8、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 8、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement: 手順 8、 3の画像 3
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: 手順 9、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 9、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement: 手順 9、 3の画像 3
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: 手順 10、 3の画像 1 Traxxas Summit Steering Assembly Servo Replacement: 手順 10、 3の画像 2 Traxxas Summit Steering Assembly Servo Replacement: 手順 10、 3の画像 3
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Carson J. Bailey
メンバー登録日: 02/28/17
117 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S4-G1, Baddour Spring 2017 University of Memphis, Team S4-G1, Baddour Spring 2017人のメンバー
UM-BADDOUR-S17S4G1
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 30
今までの合計 2,321
