メインコンテンツにスキップ
Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly
必要な工具と部品
  1. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly, Traxxas Stampede 12T Brushed Motor: 手順 1、 1の画像 1
    • Remove the fastner clips on all four corners of the body.
  2. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 2、 1の画像 1
    • Lifting straight up, remove the plastic body from the truck, exposing the inner components.
  3. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 3、 1の画像 1
    • Using a Phillips #1 screwdriver, on the rear right side, remove the center screw from the green wheelie bar.
  4. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 4、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the center screw on the left side of the green wheelie bar.
  5. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 5、 2の画像 1 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 5、 2の画像 2
    • Pull the black power wire in an outward motion on both sides of the clear plastic sleeve to disconnect the motor from the battery. Repeat this with the red power wire to disconnect it from the battery.
  6. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 6、 2の画像 1 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 6、 2の画像 2
    • Remove the right rear wheel, using a 7.0 mm socket-or R.C. wheel wrench to loosen the Nyloc nut.
    • Pull the wheel straight out removing it from the truck.
  7. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 7、 2の画像 1 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 7、 2の画像 2
    • Using a number Phillips #1 screwdriver, remove the two screws that hold the plastic motor housing together.
    • Pull the motor housing straight out and remove.
  8. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 8、 2の画像 1 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 8、 2の画像 2
    • Using a 1/16 Allen wrench, loosen the set screw inside the small gear that holds the motor in place.
    • Pull straight out to remove the gear from the motor shaft.
  9. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 9、 1の画像 1
    • Remove two Phillips #1 head screws holding the motor in place.
  10. Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 10、 2の画像 1 Traxxas Stampede Remote Control Truck 12T Brushed Motor Disassembly: 手順 10、 2の画像 2
    • Grasping the motor, slide it out towards the left tire, removing it entirely.
    • Now you have removed the old motor and can replace it with a new one.
終わりに
作成者
2人の作成者と共同で作成されました。
Ashley
メンバー登録日: 10/08/19
181 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S27-G3, Munoz Fall 2019 Eastern Washington University, Team S27-G3, Munoz Fall 2019人のメンバー
EWU-MUNOZ-F19S27G3
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 19
今までの合計 721
