メインコンテンツにスキップ
Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement
必要な工具と部品
  1. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: 手順 1、 2の画像 1 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: 手順 1、 2の画像 2
    • Remove the Torx-head screws (23.2mm) on the inside panel of the tailgate, using the torx T25 screwdriver.
  2. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 2、 2の画像 1 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 2、 2の画像 2
    • Pull off the panel and then pull cables inward, causing tailgate to release and go down.
  3. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 3、 2の画像 1 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 3、 2の画像 2
    • Remove rubber pieces from cable and pull cable from insert.
  4. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 4、 2の画像 1 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 4、 2の画像 2
    • Use your 5/16th-in. wrench to turn bolt counter clockwise and remove the bolts (18.5mm).
  5. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 5、 2の画像 1 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 5、 2の画像 2
    • Push in black clip to let handle fall out.
  6. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 6、 1の画像 1
    • Put new tailgate handle back in.
  7. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 7、 1の画像 1
    • Hand twist in bolts; then tighten with wrench.
  8. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 8、 1の画像 1
    • Insert cable back into socket and press rubber lock onto cable.
  9. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 手順 9、 1の画像 1
    • Put panel back into place and screw in using your torx -T25 screwdriver.
終わりに
This Device is a medium hardness fix but, with hard-work it can be achieved in only about 30 minutes
作成者
3人の作成者と共同で作成されました。
Brandon Gibson
メンバー登録日: 03/26/20
169 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S11-G11, Willis Spring 2020 University of Memphis, Team S11-G11, Willis Spring 2020人のメンバー
UM-WILLIS-S20S11G11
1 メンバー
1のガイドは作成済み
2 件のコメント
You skipped the problematic part about changing the lock.
Declan Haptism - 返信
I’m about to replace my handle.. I also need the 4 white clips that help align the latch rods. Mine were old brittle and all broken. Any chance you have a part number for those small clips?
Ryan Rodriguez - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 47
過去 30 日: 162
今までの合計 10,382
