メインコンテンツにスキップ
Toyota Tacoma Oil Change
必要な工具と部品
  1. Toyota Tacoma Oil Change, Toyota Tacoma Oil Change: 手順 1、 1の画像 1
    • Locate the oil drain plug. The plug is located underneath the front of the truck on the bottom of the engine crank case.
    • Warm up the engine by letting it run or driving it for 10-20 minutes to ensure the oil will flow easily.
    • Be careful not to touch the engine as it will be hot.
  2. Toyota Tacoma Oil Change: 手順 2、 1の画像 1
    • Place the drain pan under the drain plug so it will catch the oil as it falls vertically from the engine.
  3. Toyota Tacoma Oil Change: 手順 3、 1の画像 1
    • Loosen the drain plug by turning the 14mm socket counterclockwise.
    • Avoid getting oil on the ground by moving the oil pan accordingly.
    • Move your hand away from under the drain plug quickly after loosening it to avoid getting hot oil on your hand.
  4. Toyota Tacoma Oil Change: 手順 4、 3の画像 1 Toyota Tacoma Oil Change: 手順 4、 3の画像 2 Toyota Tacoma Oil Change: 手順 4、 3の画像 3
    • Pull the hood release latch. The latch is located inside of the car under the steering wheel.
    • Pull the hood release. The release is located under the front center of the hood.
    • Use the hood support rod to keep the hood propped up. The rod is located along the front edge of the engine compartment.
  5. Toyota Tacoma Oil Change: 手順 5、 2の画像 1 Toyota Tacoma Oil Change: 手順 5、 2の画像 2
    • Locate the oil filter in the engine compartment. The oil filter is on the lower right side of the engine.
    • Remove the filter by turning it counterclockwise with a wrench .
    • The wrench wraps around the filter and tightens itself as you turn it counterclockwise.
    • Use force if the filter is difficult to remove.
    • The oil filter may be hot.
    The cup underneath the filter has a fitting to allow a length of rubber hose to attach, and run down to your drain pan, so as to not spill any residual oil from the filter as it's removed.
    drivin165 - 返信
  6. Toyota Tacoma Oil Change: 手順 6、 2の画像 1 Toyota Tacoma Oil Change: 手順 6、 2の画像 2
    • Apply a small amount of fresh oil to the edge of the new filter.
    • Use your hand to tighten the new filter until it fits snugly.
    • As the engine runs, it will cause the filter to tighten itself, so it is unnecessary to use additional force to tighten the filter.
  7. Toyota Tacoma Oil Change: 手順 7、 3の画像 1 Toyota Tacoma Oil Change: 手順 7、 3の画像 2 Toyota Tacoma Oil Change: 手順 7、 3の画像 3
    • Set the torque wrench to 32 ft-lbs.
    • Check if all of the oil has drained from the engine by seeing if the oil is still flowing into the drain pan.
    • Wipe any spills on the ground.
    • Replace the drain plug.
    • Use the 14mm socket torque wrench to tighten the drain plug until the wrench makes a "clicking" noise.
    • Do not over tighten the drain plug with the torque wrench. Too much force could cause the head of the bolt to snap off and become stuck in the engine.
    Technically, you should replace the crush washer every time you remove the drain plug.
    henson - 返信
  8. Toyota Tacoma Oil Change: 手順 8、 1の画像 1
    • Locate the oil fill cap in the engine compartment. The cap is located on the lower right side of the engine next to the oil filter.
    • Remove the cap by unscrewing it counterclockwise.
  9. Toyota Tacoma Oil Change: 手順 9、 1の画像 1
    • Place the funnel into the oil fill tube.
    • Pour 5 quarts of new oil into the funnel.
    • Replace the oil fill cap.
  10. Toyota Tacoma Oil Change: 手順 10、 2の画像 1 Toyota Tacoma Oil Change: 手順 10、 2の画像 2
    • Start the truck and let it run for 5 minutes before turning off the engine.
    • Locate the engine dipstick. The dipstick is located on the left side of the engine compartment and is designated by a yellow ring.
    • Remove the dipstick and wipe it clean.
    • Reinsert and remove the dipstick to see if the oil is between the two dots on the dipstick.
    • The job is finished if the oil is between or slightly above the two dots.
    • If the oil is below the two dots, add new oil in small increments into the oil fill tube until the dipstick shows it is between the two dots.
    • Do not pour oil into the dipstick tube.
終わりに
13 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Eric Rodan
メンバー登録日: 02/24/15
369 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015人のメンバー
CPSU-GREEN-W15S23G2
4 メンバー
16のガイドは作成済み
6 件のコメント
Can you show me the 2007 Toyota Tacoma Oil Change also ?
Virgilio Pilapil - 返信
Step 3 Don’t spill the oil on the ground (pic shows a puddle of oil on the ground).
wislofsky - 返信
Can you use a EWK 6.5L Pneumatic Manual Oil Extractor Pump Vacuum Fluid Evacuator Motor Engine Oil Changer with a 2009 Tacoma?
TJQP - 返信
Can you use EWK 6.5L Pneumatic Manual Oil Extractor Pump Vacuum Fluid Evacuator Motor Engine Oil Changer on a 2009 Tacoma, or any Toyota?
TJQP - 返信
This is not applicable to the 2019 (and probably later) models. They now use canister filters located under the skid plate.
Red Fummoxed - 返信
You don’t need to replace the plug every time you change the oil.
bloggerstomper - 返信
コメントを追加
統計データ:
過去 24時間: 19
過去 7 日: 219
過去 30 日: 874
今までの合計 147,410
