はじめに
This guide outlines the steps needed to replace the impeller spindle. The spindle is the shaft that the impeller spins around.
Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
