はじめに
This guide will show you how to open your Thrive. Something that must be done for most repairs.
パーツ
パーツは必要ありません。
  1. Make sure the lock switch for the back cover is unlocked.
    • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Remove back cover by prying away from the Thrive. The easiest place to pry from is one of the two speakers.
    • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
  3. To remove the battery, make sure the lock switch is in the unlocked position.
    • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Slide the battery switch release to the right. While holding the switch in place, lift up the battery. While holding the switch in place, lift up the battery.
    • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
  6. Start by using a screwdriver to remove the 12 screws holding on the back cover.  The screws are 5mm in length and require a PH0 screwdriver. All of these screws are identical so don't worry about getting them mixed up.
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
      • All of these screws are identical so don't worry about getting them mixed up.
  7. Start to gently pry the back of the device off, while leaving it loosely in place. Be careful not to tear or damage the cables when removing the back. Be careful not to tear or damage the cables when removing the back.
    • Start to gently pry the back of the device off, while leaving it loosely in place.
      • Be careful not to tear or damage the cables when removing the back.
  8. Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown. Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown. Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  9. Carefully open the device like a book and lay the two halves beside each other. Carefully open the device like a book and lay the two halves beside each other.
    • Carefully open the device like a book and lay the two halves beside each other.
まとめ
3 の人々がこのガイドを完成させました。
Kason
メンバー登録日: 2014年09月22日
977 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014人のメンバー
USFT-BROWN-F14S10G1
3 メンバー
12のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 255
