パーツ
パーツは必要ありません。
  1. To remove the outer casing, wedge the pry tool in between the front and back panel, and pull them apart.
    • To remove the outer casing, wedge the pry tool in between the front and back panel, and pull them apart.
  2. Locate the lock switch, at the top left corner of the device, and adjust to the unlocked position. (from left to right)
    • Locate the lock switch, at the top left corner of the device, and adjust to the unlocked position. (from left to right)
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Use your fingers to push the release switch, which is located at the top right corner of the device to the right. While pushing the release switch to the right, use your other hand to pull the battery away from the inner casing.
    • Use your fingers to push the release switch, which is located at the top right corner of the device to the right.
    • While pushing the release switch to the right, use your other hand to pull the battery away from the inner casing.
  5. To replace the battery, take your replacement piece and flip it upside down, revealing the warnings and specifications of that specific battery.
    • To replace the battery, take your replacement piece and flip it upside down, revealing the warnings and specifications of that specific battery.
    • Locate the crevice at the bottom of the battery, which has black openings in it.
    • Line up the black openings with the golden prongs located on the inner casing, and slide the battery into place.
    • Move the lock/unlock switch to the locked position
まとめ
Courtney Campbell
メンバー登録日: 2014年10月22日
301 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-1, Shastany Fall 2014 UMass Dartmouth, Team 1-1, Shastany Fall 2014人のメンバー
UMASSD-SHASTANY-F14S1G1
3 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 152
