はじめに
If you’re experiencing a hardware failure or just want an upgrade to your device’s performance, this guide will walk you through the steps of replacing your hard drive.
必要な工具と部品
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
