1. Flip the laptop upside down so the back compartment is facing up.
    • Flip the laptop upside down so the back compartment is facing up.
    • Place left thumb on the battery lock tab.
    • Place right thumb on the battery release latch.
  2. Slide both tabs outward at the same time to release battery pack.
    • Slide both tabs outward at the same time to release battery pack.
    • Pull out the battery after it has popped out and set aside.
    • The battery and the battery cover are in one piece
    • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
    • Turn the device over and open it up to the display.
    • Gently lift a corner of the keyboard strip until it pops out of its position.
    • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
    • Pop the keyboard up gently and rest on top of the touch pad
    • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
    • Using a #00 phillips head screwdriver, remove the 6mm screw holding the metal plate down.
    • Gently remove the keyboard connector film from the motherboard with fingers by lifting upwards.
    • Set aside the keyboard.
    • Using a #00 phillips head screwdriver, remove the three 13mm screws holding down the touch pad's frame from underneath the keyboard.
    • Flip laptop back upside down.
    • Remove the 5mm lock screw, using a #00 phillips head screwdriver.
    • Slide bay latch toward the battery compartment.
    • Remove CD-RW/DVD-ROM drive.
    • Remove the 4.5mm screw located under the CD-RW/DVD-ROM drive compartment, using a #00 phillips head screwdriver.
    • Remove the three 17mm screws found on the backside of the laptop using a #00 phillips head screwdriver.
    • Remove the ten 8mm screws using a #00 phillips head screwdriver.
    • Flip the laptop back over and unplug the touch pad's power cord from the motherboard gently using a pair of tweezers.
    • Lift off the plastic cover and set it aside.
    • Using a #00 phillips head screwdriver, unscrew the three 5mm screws holding down the heat sink securing bracket.
    • Lift off the securing bracket and set aside.
    • Wiggle the heat sink until it lifts off the top of your CPU. There is thermal paste underneath and it may stick.
    • Turn a flathead #3 screwdriver counter-clockwise to unlock the CPU socket.
    • Grab the CPU with your index finger and thumb and pull directly upwards.
    • Apply a new coat of thermal paste before reassembling.
まとめ
2 の人々がこのガイドを完成させました。
Cindy Nguyen
メンバー登録日: 2014年09月08日
386 ポイント
3のガイドは作成済み
チーム
CSU Fullerton, Team 1-6, Bruce Fall 2014 CSU Fullerton, Team 1-6, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S1G6
3 メンバー
3のガイドは作成済み
コメント1件
"Step 4 - CPU" THAT IS NOT A 8MM SCREW! THERE IS NOW A HOLE IN MY COMPUTER!!
RetroGamerTomppa - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,026
