メインコンテンツにスキップ
Toshiba TY-LP 200 Belt Replacement
必要な工具と部品
  1. Toshiba TY-LP 200 Belt Replacement, Belt: 手順 1、 2の画像 1 Toshiba TY-LP 200 Belt Replacement, Belt: 手順 1、 2の画像 2
    • Unplug the turntable and remove the dust cover by lifting the lid horizontally.
  2. Toshiba TY-LP 200 Belt Replacement: 手順 2、 2の画像 1 Toshiba TY-LP 200 Belt Replacement: 手順 2、 2の画像 2
    • Locate the C-clip at the center base of the platter and remove it with a flathead screwdriver.
  3. Toshiba TY-LP 200 Belt Replacement: 手順 3、 2の画像 1 Toshiba TY-LP 200 Belt Replacement: 手順 3、 2の画像 2
    • Once removed, very gently lift the platter straight up and off the device.
    • Flip the platter upside down.
  4. Toshiba TY-LP 200 Belt Replacement: 手順 4、 3の画像 1 Toshiba TY-LP 200 Belt Replacement: 手順 4、 3の画像 2 Toshiba TY-LP 200 Belt Replacement: 手順 4、 3の画像 3
    • Place the new belt around the center ring of the upside-down platter.
    • After placing the new belt, stretch the belt towards one of the indented areas on the back of the platter.
  5. Toshiba TY-LP 200 Belt Replacement: 手順 5、 1の画像 1
    • Locate the spool drive that is surrounded by three screws.
  6. Toshiba TY-LP 200 Belt Replacement: 手順 6、 1の画像 1
    • Once you have located the spool drive, place the stretched belt over it, and gently put back the platter into its original form, as shown in step 2.
    • If this step is done correctly, once the platter is spun, it will stop by itself.
  7. Toshiba TY-LP 200 Belt Replacement: 手順 7、 2の画像 1 Toshiba TY-LP 200 Belt Replacement: 手順 7、 2の画像 2
    • Place the C-type back into its original place and, with your finger, attach it onto the spindle.
    • Reinstall the dust cover by placing it on the snaps and applying force downwards.
終わりに
You now have a fixed and working record player.
作成者
1人の作成者と共同作成されました。
Andrew
メンバー登録日: 05/14/20
145 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G28, O'Regan Summer 2020 York University, Team S1-G28, O'Regan Summer 2020人のメンバー
YORK-O'REGAN-SU20S1G28
1 メンバー
1のガイドは作成済み
3 件のコメント
Thank you so much for this! Incredibly helpful!!!
Judi Dell'Anno - 返信
Replacement belt size?
lyam_pa - 返信
Along with this fix, I tried to clean a bit of dust and grime that's accumulated throughout the 3 decades. Some is not coming off with vacuuming or dry-wiping. Any advice on how to clean the unit up before reassembly? Mine is a gold Marantz with similar design and some of its parts are not as smooth as they should be. Thanks so much
Edie K - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 1,191
