メインコンテンツにスキップ
Toshiba TECRA R940 Fan Replacement
必要な工具と部品
  1. Toshiba TECRA R940 Fan Replacement, Battery: 手順 1、 2の画像 1 Toshiba TECRA R940 Fan Replacement, Battery: 手順 1、 2の画像 2
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Fan Replacement: 手順 2、 2の画像 1 Toshiba TECRA R940 Fan Replacement: 手順 2、 2の画像 2
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Fan Replacement, Back Panel: 手順 3、 2の画像 1 Toshiba TECRA R940 Fan Replacement, Back Panel: 手順 3、 2の画像 2
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Fan Replacement: 手順 4、 2の画像 1 Toshiba TECRA R940 Fan Replacement: 手順 4、 2の画像 2
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Fan Replacement: 手順 5、 1の画像 1
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Fan Replacement: 手順 6、 2の画像 1 Toshiba TECRA R940 Fan Replacement: 手順 6、 2の画像 2
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Fan Replacement: 手順 7、 2の画像 1 Toshiba TECRA R940 Fan Replacement: 手順 7、 2の画像 2
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
  8. Toshiba TECRA R940 Fan Replacement, Fan: 手順 8、 1の画像 1
    • Remove two 3.5 mm screws with a Phillips #0 screwdriver from either side of the fan.
  9. Toshiba TECRA R940 Fan Replacement: 手順 9、 1の画像 1
    • Disconnect the fan from its port.
終わりに
作成者
2人の作成者と共同で作成されました。
Holly Strauch
メンバー登録日: 09/23/18
409 ポイント
4のガイドは作成済み
チーム
Central Washington University, Team S1-G5, Pengilly Fall 2018 Central Washington University, Team S1-G5, Pengilly Fall 2018人のメンバー
CWU-PENGILLY-F18S1G5
3 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 1,456
