はじめに
If you need to replace the hard drive, follow this guide. The hard drive is located underneath the computer. To replace this part, you will need a Phillips 00 screw driver and a plastic prying tool. This process should not require any excessive force.
必要な工具と部品
Remove the battery by sliding the tabs to the left.
Use the spudger to lift the battery out.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
