メインコンテンツにスキップ
Toshiba Satellite e205 Wireless Card Replacement
必要な工具と部品
  1. Toshiba Satellite e205 Wireless Card Replacement, Battery: 手順 1、 2の画像 1 Toshiba Satellite e205 Wireless Card Replacement, Battery: 手順 1、 2の画像 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Wireless Card Replacement, Keyboard: 手順 2、 1の画像 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Wireless Card Replacement: 手順 3、 1の画像 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Wireless Card Replacement: 手順 4、 1の画像 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Wireless Card Replacement, Bottom Cover: 手順 5、 1の画像 1
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Wireless Card Replacement: 手順 6、 1の画像 1
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Wireless Card Replacement: 手順 7、 1の画像 1
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Wireless Card Replacement: 手順 8、 2の画像 1 Toshiba Satellite e205 Wireless Card Replacement: 手順 8、 2の画像 2
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Wireless Card Replacement: 手順 9、 2の画像 1 Toshiba Satellite e205 Wireless Card Replacement: 手順 9、 2の画像 2
    • Remove the two screews.
  10. Toshiba Satellite e205 Wireless Card Replacement: 手順 10、 1の画像 1
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Wireless Card Replacement: 手順 11、 1の画像 1
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Wireless Card Replacement: 手順 12、 1の画像 1
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  13. Toshiba Satellite e205 Wireless Card Replacement, Wireless Card: 手順 13、 2の画像 1 Toshiba Satellite e205 Wireless Card Replacement, Wireless Card: 手順 13、 2の画像 2
    • Locate the wireless card.
    • Remove the white antenna lead.
    • Remove the single screw.
    • Lift the card up from the edge with the screw, and pull out.
終わりに
Tyler
メンバー登録日: 06/19/12
4,920 ポイント
16のガイドは作成済み
チーム
TechForce TechForce人のメンバー
Business
2 メンバー
25のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 15
今までの合計 354
