この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The function of the keyboard is to allow you to type on the computer. Sometimes it can break and need to be replaced.
必要な工具と部品
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
2 の人々がこのガイドを完成させました。
