はじめに
Sometimes the hard drive is corrupt, or you want to install a new one. This guide will show you how to take out a hard drive and replace.
必要な工具と部品
Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
2 の人々がこのガイドを完成させました。
