はじめに
The faceplate is the area next to the keyboard that protects the inside parts of the device. Sometimes it may need to be taken off to repair other parts. This guide will show how to remove it.
必要な工具と部品
Turn the laptop over.
Slide back the left lock, and you should hear a click when it is successfully locked back in.
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
With the keyboard removed, locate the marked screws.
Remove the marked, 5mm screws using the #1 Phillips Screwdriver.
ある他の人がこのガイドを完成しました。
