メインコンテンツにスキップ
Toshiba Satellite S75D-A7346 Hard Drive Replacement
必要な工具と部品
  1. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The Battery: 手順 1、 2の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The Battery: 手順 1、 2の画像 2
    • First we have to take out the battery
    • Pull the switch on the left to the left
    • then hold the switch on the right to the right direction
    • then pull up the bttery from the point inbetween the 2 switches
  2. Toshiba Satellite S75D-A7346 Hard Drive Replacement, UnScrewing The BackPlate: 手順 2、 2の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, UnScrewing The BackPlate: 手順 2、 2の画像 2
    • Unscrew the screw located next to the information sticker
    • Then get a screw driver or prier to gently pry the covering plate
  3. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The HDD: 手順 3、 2の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The HDD: 手順 3、 2の画像 2
    • Unscrew the black screws and then pull the black tab to the right
    • Then lift it out and place it somewhere
  4. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking The HDD Of the Mount: 手順 4、 2の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking The HDD Of the Mount: 手順 4、 2の画像 2
    • Unscrew the silver screws and move the hard drive somewhere else
  5. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Adding The New HDD/SSD To The Mount: 手順 5、 1の画像 1
    • Screw the silver screws into the screw slots furthest away from the connectors
    • Note: This computer is only compatible with 2.5 inch SATA 3Gbps
  6. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Connecting The HDD/SSD: 手順 6、 2の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Connecting The HDD/SSD: 手順 6、 2の画像 2
    • Put the Hard Drive in slot (make sure the connectors are on the same side of the connectors
    • Push the Hard Driver into the connector and screw the black screws in
  7. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting On The Backplate: 手順 7、 2の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting On The Backplate: 手順 7、 2の画像 2
    • Put on the backplate and put pressure arround the edges of the blackplate so it stays flat with the case
    • Then screw in the screw next to the information sticker
  8. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: 手順 8、 3の画像 1 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: 手順 8、 3の画像 2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: 手順 8、 3の画像 3
    • Place the battery in the slot
    • Then hold the right switch to the right and push the battery in, then release the switch.
    • move the left switch to the right
  9. Toshiba Satellite S75D-A7346 Hard Drive Replacement, You Finished: 手順 9、 1の画像 1
    • You have know finished the replacement
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Emil Lambert
メンバー登録日: 12/16/16
228 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 466
