はじめに
If your Toshiba Satellite S55t-C5225 sound quality is poor or if they are no longer operational then the battery most likely needs to be replaced. Operational speakers provide crisp sound quality without interruption. Follow this quick and easy guide for replacement.
必要な工具と部品
Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
Pull the ribbon wire out from plastic clamp.
ある他の人がこのガイドを完成しました。
