メインコンテンツにスキップ
Toshiba Satellite S55t-C5225 Speakers Replacement
必要な工具と部品
  1. Toshiba Satellite S55t-C5225 Speakers Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 2、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 2、 2の画像 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 3、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 3、 2の画像 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: 手順 4、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: 手順 4、 2の画像 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 5、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 5、 2の画像 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 6、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 6、 2の画像 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Speakers Replacement, Speakers: 手順 7、 1の画像 1
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 8、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 8、 2の画像 2
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 9、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 9、 2の画像 2
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 10、 2の画像 1 Toshiba Satellite S55t-C5225 Speakers Replacement: 手順 10、 2の画像 2
    • Lift speakers up from their mounted position to remove.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ali Mortada
メンバー登録日: 10/21/19
217 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 UMass Dartmouth, Team S1-G5, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G5
3 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 883
