メインコンテンツにスキップ
Toshiba Satellite S55t-C5225 Screen Assembly Replacement
必要な工具と部品
  1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 2、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 2、 2の画像 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 3、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 3、 2の画像 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: 手順 4、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: 手順 4、 2の画像 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 5、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 5、 2の画像 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 6、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 6、 2の画像 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Speakers: 手順 7、 1の画像 1
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 8、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 8、 2の画像 2
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 9、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 9、 2の画像 2
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 10、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 10、 2の画像 2
    • Lift speakers up from their mounted position to remove.
  11. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: 手順 11、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: 手順 11、 2の画像 2
    • Disconnect LAN from the motherboard power wire. Pop up the white clamp that holds it in place, then pull the wire out.
  12. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 12、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 12、 2の画像 2
    • Disconnect the two cables connecting the screen assembly to the WIFI card.
  13. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 13、 3の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 13、 3の画像 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 13、 3の画像 3
    • Disconnect all remaining cables that connect the screen assembly to the motherboard.
  14. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 14、 1の画像 1
  15. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 15、 2の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 15、 2の画像 2
    • Remove the four 7.0 mm Phillips #0 screws on both ends of the laptop that attach the screen assembly to the laptop.
  16. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 16、 3の画像 1 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 16、 3の画像 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: 手順 16、 3の画像 3
    • Slowly open laptop while the bottom is facing up. Begin to separate the bottom of laptop from the screen assembly brackets.
    • Remove the screen assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Javien Delgado
メンバー登録日: 10/21/19
220 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 UMass Dartmouth, Team S1-G5, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G5
3 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 793
