はじめに
If your Toshiba S55t-C5225 can no longer read CD’s/DVD’s or will not open then your optical disk drive is most likely not operational and needs to be replaced. The following steps are a guide to help the user in replacing the optical disk drive.
必要な工具と部品
Carefully slide the optical disk drive to the right to remove from the motherboard.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
