メインコンテンツにスキップ
Toshiba Satellite S55T-B5335 Cooling Fans Replacement
必要な工具と部品
  1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Battery: 手順 1、 1の画像 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 2、 3の画像 1 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 2、 3の画像 2 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 2、 3の画像 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: 手順 3、 2の画像 1 Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: 手順 3、 2の画像 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 4、 1の画像 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 5、 1の画像 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Cooling Fans: 手順 6、 1の画像 1
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 7、 1の画像 1
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 手順 8、 1の画像 1
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
George Gillespie
メンバー登録日: 09/15/16
721 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S2G1
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 1,497
