はじめに
The guide demonstrates how to replace a cooling fan for the Toshiba Satellite S50-B. You will need the Phillips #0 screwdriver and the plastic opening tool.
必要な工具と部品
Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
Use a plastic opening tool to remove the bottom panel.
ある他の人がこのガイドを完成しました。
