このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Starting on the edge that is opposite the hinge, use the plastic opening tools to pry the back plate away from the computer.
Loosen the three non-hinge edges.
Leave a plastic opening tool in each corner to ensure that one side does not snap closed before you are done opening the others.
この手順は未翻訳です。 翻訳を手伝う。
To loosen the back plate, lift it slightly and gently pull it away from the hinge.
Flip the back plate open towards the power button, but be sure to not pull on the ribbon cable that connects the back plate to the motherboard.
Use a plastic opening tool to detach the side of the ribbon cable connected to the computer by prying up gently on the small black lever at the point of attachment.
ある他の人がこのガイドを完成しました。
