メインコンテンツにスキップ
Toshiba Satellite P855-S5312 Fan Replacement
必要な工具と部品
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite P855-S5312 Fan Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite P855-S5312 Fan Replacement, Battery: 手順 1、 3の画像 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: 手順 2、 3の画像 1 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: 手順 2、 3の画像 2 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: 手順 2、 3の画像 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: 手順 3、 3の画像 1 Toshiba Satellite P855-S5312 Fan Replacement, Fan: 手順 3、 3の画像 2 Toshiba Satellite P855-S5312 Fan Replacement, Fan: 手順 3、 3の画像 3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: 手順 4、 2の画像 1 Toshiba Satellite P855-S5312 Fan Replacement: 手順 4、 2の画像 2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: 手順 5、 3の画像 1 Toshiba Satellite P855-S5312 Fan Replacement: 手順 5、 3の画像 2 Toshiba Satellite P855-S5312 Fan Replacement: 手順 5、 3の画像 3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: 手順 6、 2の画像 1 Toshiba Satellite P855-S5312 Fan Replacement: 手順 6、 2の画像 2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: 手順 7、 3の画像 1 Toshiba Satellite P855-S5312 Fan Replacement: 手順 7、 3の画像 2 Toshiba Satellite P855-S5312 Fan Replacement: 手順 7、 3の画像 3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Dalton
メンバー登録日: 10/02/17
215 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S10G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 579
