はじめに
This guide will help the user replace the disk drive on the Toshiba Satellite P855-S5312 . Reasons for replacement include jammed or unresponsive disk. Philips size 0, Tools required for task are phillips size 0 Screwdriver, Plastic Opening Tools, and Pointed edge tool.
必要な工具と部品
Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
Move the sliders to the left and right to release the tabs holding the battery in.
While the tabs are pushed outwards, remove the battery from the device.
Once laptop is turned over with the spine facing you, locate the large L shape panel.
Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
Flip your device over and rotate the side of the optical drive over to you.
Unclip the clips on the side of the automatic release.
Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
Once released slide the aluminum case out.
