メインコンテンツにスキップ
Toshiba Satellite P855-S5312 Disk Drive Replacement
必要な工具と部品
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: 手順 1、 3の画像 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: 手順 2、 2の画像 1 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: 手順 2、 2の画像 2
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 3、 2の画像 1 Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 3、 2の画像 2
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 4、 2の画像 1 Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 4、 2の画像 2
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 5、 2の画像 1 Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 5、 2の画像 2
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 6、 3の画像 1 Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 6、 3の画像 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: 手順 6、 3の画像 3
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
終わりに
作成者
3人の作成者と共同で作成されました。
Bishop Clark
メンバー登録日: 10/02/17
225 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S10-G2, Thompson Fall 2017 USF Tampa, Team S10-G2, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S10G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 480
