はじめに
A broken touchpad is annoying on any laptop. Sometimes this is an easy fix. Use this guide to fix a disconnected touchpad on your Toshiba Satellite P755 S5390.
必要な工具と部品
Close the cover and turn the laptop over so that the spine is facing away from you.
Grab the blue plastic above the touch pad wire.
Firmly plug the cable into its socket on the motherboard.
If you need information on how to remove or replace connectors take a look at the Recognizing and Disconnecting Cable Connectors guide.
5 の人々がこのガイドを完成させました。
