はじめに
Through this guide you will learn to replace the fan inside of your laptop. Make sure you have the proper tools in order to complete the repair. This kind of repair is usually done to fix the problem of your laptop overheating.
必要な工具と部品
Using a Phillips #1 screwdriver, remove the screw from the back cover.
Remove the back cover from the device.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
