はじめに
Is your Toshiba Satellite P55W-C5200X running very slowly and slow to respond, or is it not even turning the screen on? The cause may lay with a faulty or mismatched RAM. You may not have enough RAM or may not have a compatible type to your motherboard. For any of these reasons a replacement or change may be in order.
All tools that will be needed are listed below to gain access and change out your devices RAM. This is a very simple process and low risk as well, the only advise would be to make sure the device is turned off and to be careful when handling the RAM and the slots they go into.
This guide will tell Toshiba Satellite P55W-C5200X users how to replace there RAM. It is an easy-level process that takes 5-10 minutes to complete.
必要な工具と部品
Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
ある他の人がこのガイドを完成しました。
