メインコンテンツにスキップ
Toshiba Satellite P55W-C5200X Keyboard Replacement
必要な工具と部品
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 手順 1、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 手順 1、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 手順 1、 3の画像 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 2、 1の画像 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 3、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 3、 2の画像 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 4、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 4、 2の画像 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 5、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 5、 2の画像 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 手順 6、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 手順 6、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 手順 6、 3の画像 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 手順 7、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 手順 7、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 手順 7、 3の画像 3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 8、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 8、 2の画像 2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 9、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 9、 2の画像 2
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: 手順 10、 1の画像 1
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 11、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 11、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 11、 3の画像 3
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 12、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 12、 2の画像 2
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 13、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 13、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 13、 3の画像 3
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 14、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 14、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 14、 3の画像 3
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 15、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 15、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 15、 3の画像 3
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 16、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 16、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 16、 3の画像 3
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 17、 2の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 17、 2の画像 2
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 18、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 18、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 18、 3の画像 3
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 19、 3の画像 1 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 19、 3の画像 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 手順 19、 3の画像 3
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Vatthanak Doeung
メンバー登録日: 10/21/19
223 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019人のメンバー
UMASSD-BOTVIN-F19S1G2
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 54
今までの合計 1,439
