はじめに
If your Toshiba Satellite P55W-C5200X keyboard is not responding it may be time for a replacement. Keyboards may become unresponsive if there is a build up of dirt or other materials in the keys. If not it may be a more severe problem and would require a full replacement of the keyboard itself.
The tools needed to gain access to the keyboard are listed below . This is a low risk operation, the only requirement for safety is to make sure the device is turned off before starting and keeping away from liquids while working on the device.
This guide will tell Toshiba Satellite P55W-C5200X users how to replace a defective keyboard.
必要な工具と部品
Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
Once the fan, ram, and battery are removed, remove the motherboard.
Detach the three connecting wires.
Remove the white, blue-tipped cable ribbon too.
ある他の人がこのガイドを完成しました。
