この分解は進行中です。 – 最新版を見るには定期的に再読み込みします。
はじめに
In this guide I will show you how to replace various parts in the Toshiba Satellite P55T Series.
The Satellite P55t-A1158 has an  Intel Core i7-4500U,  Intel HD graphics, a 1 TB (5400 RPM) HDD and 8GB DDR3L. (Mine has 16GB)
  • The Satellite P55t-A1158 has an Intel Core i7-4500U, Intel HD graphics, a 1 TB (5400 RPM) HDD and 8GB DDR3L. (Mine has 16GB)
Power off the device before disassembly. This is very important.
  • Power off the device before disassembly. This is very important.
    • Try to discharge your battery below 20%. A charged Li-On battery can catch fire and/or explode if accidentally punctured.
新しいバッテリー=より速いiPhone
最低購入価格 $16.99
Flip the device over and remove the single screw holding the memory cover on. Use a Spudger to pry it open The single Phillips screw The single Phillips screw
  • Flip the device over and remove the single screw holding the memory cover on. Use a Spudger to pry it open
    • The single Phillips screw
Pads with screws under them.
  • Pads with screws under them.
    • More screws..... Wait, NOPE. Those pads have no screws
添付文書
Reed Crosby
メンバー登録日: 2016年12月07日
2,119 ポイント
3のガイドは作成済み
チーム
Kid fixers Kid fixers人のメンバー
Community
58 メンバー
43のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 105
