メインコンテンツにスキップ
Toshiba Satellite P205D-S8804 CD Drive Replacement
必要な工具と部品
  1. Toshiba Satellite P205D-S8804 CD Drive Replacement, Keyboard: 手順 1、 1の画像 1
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 2、 1の画像 1
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 3、 1の画像 1
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 4、 1の画像 1
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 5、 2の画像 1 Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 5、 2の画像 2
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 6、 1の画像 1
    • Once the ribbon is released the keyboard can be removed .
  7. Toshiba Satellite P205D-S8804 CD Drive Replacement, CD Drive: 手順 7、 1の画像 1
    • Flip the computer over with the hinge facing you.
    • Remove one screw that is located in the Toshiba lable on the bottom of the computer.
  8. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 8、 1の画像 1
    • Flip the computer back over and push the metal tab to the right to release the CD drive from its docking port.
  9. Toshiba Satellite P205D-S8804 CD Drive Replacement: 手順 9、 1の画像 1
    • Remove the CD Drive.
終わりに
作成者
4人の作成者と共同で作成されました。
Caroline Camp
メンバー登録日: 01/30/17
1 ポイント
3のガイドは作成済み
チーム
Baylor, Team 3-2, Whitney Spring 2017 Baylor, Team 3-2, Whitney Spring 2017人のメンバー
BU-WHITNEY-S17S3G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 12
今までの合計 140
